Hydraulic Lines damaged often
Tweetybrun
L 3200 Tractor Loader B/H RTV x1100c Grand L 4060 FL 805, BH 9.2
Jul 28, 2014
71
Hancock New York
I have a Factory Installed 3rd function remote on my Grand L. The hydraulic lines come off hard lines under the cab near the right step. The lines are in a vulnerable position and constantly being hit by branches and debris. Does anyone have a suggestion to protect or reroute the hydraulic lines to the rear of the tractor? IMG_2464.jpeg IMG_2464.jpeg
5,187
I have a Factory Installed 3rd function remote on my Grand L. The hydraulic lines come off hard lines under the cab near the right step. The lines are in a vulnerable position and constantly being hit by branches and debris. Does anyone have a suggestion to protect or reroute the hydraulic lines to the rear of the tractor? View attachment 124375 View attachment 124375
You should probably contact: Specialtyrepairsandcustommods.com, in Bay Roberts, NL, Canada.
1-709-786-3348.
This husband/wife team makes and ships, all sorts of very high quality custom upgrades, specifically for Kubota tractors.
They are first class folks!
bearskinner
Sep 1, 2014
926
242
N. Idaho
Looks like it would be easy to bolt on ( so you don’t have to weld) some angle iron to the bolted on brackets that are there now. And sandwich piece if expanded metal or … to let the debris come out.
If you have the ability to weld up a piece, you can make a cover to bolt on.
6,295
1st ,I'd add 90* adapters between hoses and 'the block'. If left asi is ,I can see the hoses failing between the wraps of tape and the sheathing. Might take a year or two , depending on actual use,but they'll fail for sure.
2nd, yes, say some 1/8" sheeting,bent and bolted as required.
loggin
MX4700
Sep 4, 2021
111
39
canada
It is difficult to see from your photo where the lines are running to but is it possible to replace the hard lines with flexible lines and do a complete reroute?
4,213
That’s very “sloppy” of Kubota to have so poorly-designed that…. They should include those aftermarket shields as Standard equipment.
Tweetybrun
Jul 28, 2014
71
Hancock New York
Have you seen any aftermarket shields? If so please point me in that direction. I’m anxious to install them. These hydraulic lines are the heartbeat of the machine.
  • Sad
Tweetybrun
Jul 28, 2014
71
Hancock New York
I’m sorry, I just saw the previous reply. They point toward the guards.
thank you.
Tweetybrun
Jul 28, 2014
71
Hancock New York
Not cheap,...... but really good stuff!
Thank you. I am definitely going to purchase both. I’m surprised I got away without them this long. I’m waiting on replacement hoses probably $140 plus a week without the machine.
5,187
You will like dealing with that couple (Paul & Kathy Short) in Bay Roberts, NL.
5,187
Have a great weekend.
Thank you!
I always have a chuckle, when folks say "Have a great weekend".
I have been retired for 24 years.
Every day is a weekend day for me!
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
Thank you!
Father in law always says that being retired is hard work. You never get a day off again.
6,295
yes ! since I retired 35 years ago, it seems 'everyone' KNOWS I have 'free' time and expect their 'ruxh' job to be put ahead of everyone else's 'rush' job and that I should stop all MY jobs for them......
I'd explain further but someone's at the garage with a ded rider and a snowbower.....gotta go...
11,757
If you didn't learn the first time that driving through brush on a SCUT/CUT isn't a good idea then you need to keep learning
Yep! It'd be a cold day in hell before I'd spend $350 on a piece of folded 1/4" plate.
It's so easy to design and make your own stuff when you have a way to cut and weld steel. Invest $1,000 on some half decent metal working tools and stop paying someone else's mortgage ... that's my tip of the day!! 😂
By the way, a 2ft x 2ft x 1/4" piece of steel is around $80, and that's paying full retail!
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
Isn't that the truth. I've been retired for 7 years now and probably working harder (on my property each day) than I did at my regular day job (which was demanding). But I have to say....at least it is by 'choice' and I can start or stop as I wish. (y)
So not complaining. It is all self imposed.
