Hydraulic Leak at loader valve
hackw1rm
L3600 GST
Mar 30, 2015
Jackson, MI
Hello just bought a 1995 L3600 GST. While running it I noticed a steady drip of fluid coming from my loader stick. I have attached a photo of where it's located. Anyone had this before? What type of repair am I looking at? Bad seal in there causing this or something more then that? Thanks for any help you may give.
8,792
A loader valve rebuild kit will fix it up, looks like it's leaking at the O-ring fitting under the metal plate. ;)
hackw1rm
L3600 GST
Mar 30, 2015
Jackson, MI
Thanks wolfman, new here so I think I might of posted this in the wrong forum. Ill be working on this today so hopefully it goes smoothly. Thanks again
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
did my bx-backhoe last year ..
clean the area throughly before disassembly to avoid contamination
have spare split pins handy
remove split pin
unbolt plate (you may need to remove control lever to lift of plate)
replace o-rings & plastic washer
re-assemble
hackw1rm
L3600 GST
Mar 30, 2015
Jackson, MI
So I have everything put back together except for the spring and ball bearings and cap spool. How does this go back together. Should I have done the ball bearings on an earlier step?
8,792
I'm not 100% sure but try this.
First remove the 3 parts (in Blue circle), from the cover.
Use a small amount of grease on the 4 small balls to hold them in place.
Insert cover, install spring and ball and then bottom cover.
