Hydraulic hose break and now a fluid leak
cgerhardt
Kubota B26 Tractor Loader Back Hoe, Rotary Cutter, Box & Grader Blade
Mar 16, 2020
Reno
I have a hydraulic leak on my b26. It is a 2015 and I recently had to replace 2 hydraulic hoses that broke. I was doing some heavy bucket work moving dirt and with a heavy disc on the back. I am wondering if this put extra pressure on the hoses that caused that issue. After replacing those hoses, I am now getting a leak with oil coming from the lower pan where you drain the fluid. I can't find where the leak is coming from. It is not from the hoses I replaced. Perhaps a seal? Where should I look. Also, any thoughts as to what may have caused this leak.
Thanks
2,863
I would think that "old hoses" tend to get old! If one broke and you had to replace and then another- chances are ALL of them will need to be replaced at one point.
As for working the machine hard - the hydraulics can ONLY get to "X" psi before the relief valve kicks in - so the pressure may not have been the problem - but the fluid does get rather hot and thus places more strain on those hoses, as does sunlight etc.....
I would find a way to wash away the "leak" area - clean it somehow, some will say take some baby powder and sprinkle it around the area you think is leaking and look for wet powder.
A picture OF THE AREA will help a great deal too
lynnmor
B2601-1
May 3, 2021
1,629
1,411
Red Lion
Neil Messick did a YouTube video on that subject showing some high readings. A hydraulic cylinder can act as a pump when it is forced to move.
cgerhardt
Mar 16, 2020
Reno
[/QUOT
Thanks, that's helpful!
9,153
All of your issues could have something to do with a system over pressure.
And if you have a leak in the tank it could be a vent issue causing overpressure.
