Hydraulic connection point?
samuelb225
L2350
Feb 21, 2017
Prairieville,Louisiana
Can anyone tell me where I should tie into my hydraulics to run a front loader. I have a L2350 4WD and purchased a used loader and now I'm trying to make connections. My tractor has no accessory block but it does have power steering so I was thinking that maybe an access point? The loader is from another brand but did come with the controls which has 4 hydraulic lines.Any info would be great
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
331
Herald Calif.
Hello
If you go to the L2350DT Parts book page 100 is my book. You will see the block you need to add . Part # 32400-99810 It goes right under the seat were the pressure line comes from the hydraulic pump.You will remove the round cover and install the block. You might check with the company that made your loader as they may make a block. The last one I got from Bush Hog was way less the kubota charges for there block. Hope this help.
Good Luck Lance
7,386
Did this part number work for you and not lose power steering and 3-point function?
You are replying to a 5 year old thread. The block is a simple diverter that diverts the 3pt oil flow out to the implement valve and provides a return port for the flow to continue on to the 3pt. As long as the implement valve returns the diverted oil the 3pt works fine.
PuraVida
Kubota L2350
Feb 29, 2020
29
Wilmington
Thanks Dan, recent thread compared to a 25-year-old tractor. I'm finding numerous P/N's for that manifold for the 2350 so I was trying to find out if your P/N worked for you to eliminate the manifold as my issue. I'm going to look towards the loader valve instead, particularly the power beyond sleeve.
tgol8184
L2350
May 8, 2026
MD
You have any luck with this I have a L2350 I want to put a loader on and cannot find the part that goes under the seat to tie into no one has it and kubota doesn't make it
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,060
2,503
WestTn/NoMs
You have any luck with this I have a L2350 I want to put a loader on and cannot find the part that goes under the seat to tie into no one has it and kabota doesn't make it
The OP, like you, was trying to hook up a new loader. PuraVita already had a loader so, unless he had a PTO powered loader, he didn't need the block.
@TheOldHokie and someone else on here have made some of those blocks. They'll probably respond here.
You may want to edit your brand spelling; the moderator here is kinda touchy about that! 🙂
@torch also made and sold some.
tgol8184
L2350
May 8, 2026
MD
Thanks for the info and the old talk to text got me on that one I fixed it but yeah if someone makes that hydraulic block for the L2350 so i can tie my loader lines in let me know I definitely want to keep the tractor. It's in great shape and low hours. Not sure what year it is 1000006783.jpg
11,331
Thanks for the info and the old talk to text got me on that one I fixed it but yeah if someone makes that hydraulic block for the L2350 so i can tie my loader lines in let me know I definitely want to keep the tractor. It's in great shape and low hours. Not dure what year it is View attachment 180739
On that model, if you can't get someone to make you the block, it's easy to break the feed line and put 2 fittings on the ends to supply the loader valve.
Here is a block for sale, it isn't cheap!
