How to turn with a Roto tiller?
GEPM64
B2601 with FEL, Box Scraper, rotary mower, 3pt snowblower and Sovema Tiller
Sep 15, 2014
78
Hazelridge, Manitoba, Canada
Just picked up my tiller last week and spent the day on it today. One thing I'm unsure of is when tilling a large area is it ok to turn with the tiller in the ground or should I stop, raise the tiller then turn the corner before tilling again? Don't want to beak anything.
Thanks,
Glenn
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
You would have to lift it and then turn.
Unlike a rear wheel with a differential that give when you turn.
All the tines rotate at the same rate.
Ray
DocGP
117
SE TX
The tiller is chewing up the dirt. It doesnt care if one side is moving a bit faster than the other. Doesn't hurt anything to turn while you till but my OCD side really likes nice straight rows !!
Doc
mickeyd
Mar 21, 2014
1,192
Guin, AL
Here is what my Tiller Manual states: "15. Do not make turns or attempt to back up while tiller is in the ground. See important note below."
"IMPORTANT: Turning or backing up with rotary
tines in the ground will damage the tiller."
So I ALWAYS pick up the tiller before turning.
Tooljunkie
May 13, 2014
4,150
Small turns or corrections are fine. A slow turn will be fine, buried deep as it will go and a hard turn may cause premature failure of something.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
When turning lets say left.
Your left rear tire becomes the turning axis.
So when your front end is going left any thing behind the rear tire is pushed right.
So there are multiple forced on the tiller as you turn.
Ray
3,752
If I may as one that has broken more than one tiller,, small little bites until is all chewed up then like stated SLOW EASY turn are possible. Like I said SLOW AND EASY.. on fresh stuff always go in a straight line and if you need to make say a wide sweeping turn do it slowly and just a little bit of depth at a time until is all the way down. Don't back it up trying to cut into hard pan, it might never break anything then again,,,, it has ,,, Just follow the manufacture's recommendations and you will be ok,,, Just MHO
your mileage may vary
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
You can always use a different ground engagement tool first on virgin ground as well, like a plow or a buster/ripper. Once the ground is a little loose, what Skeets said is pretty much on the mark.
If you've ever run a hand (push/pull) tiller, you get the idea of the limitations very quickly.
