I am beginning to say bad things about Kubota. Can someone tell me how to remove the dash? I have remove 4 screws and the key receptacle. Something is holding it in the top center of the dash. I am afraid to apply to much pressure because I'm not sure it is suppose to pop loose and don't know the direction to pry. I have applied pressure up and out without any success. If you look under the hood there is to large bolts on the firewall but the are 4" each side of where the dash is being held. See notes on attached photos about hole in center top of dash . The hole alines with where the dash is being held but points up towards the dark gray plastic. I can't find a screw to remove with the screw driver. Thanks in advance
