How to apply paint
awesome
B2601, BH70, K54-22-06B
Sep 16, 2018
243
170
ottawa
Hi everyone,
I'm thinking about adding a mesh on the front guard of my B2601. I was wondering how I would go about painting it after. If I buy the Kubota orange spray paint, can I just paint all over, overlapping over the already painted guard? Or would I need to first sand down the original guard?
Or should I just paint the mesh before welding it?
Bmyers
May 27, 2019
3,173
3,661
Southern Illinois
I had mesh welded on, then laid the whole thing on cardboard in the driveway and spray painted one side. Dry, flip and paint the other side.
awesome
Sep 16, 2018
243
170
ottawa
ok good. So no sanding down the already painted metal then? And the paint sticks on perfectly?
NHSleddog
B2650
Dec 19, 2019
2,149
1,823
Southern, NH
It all depends on the quality you are looking for.
Weld first regardless.
The rattle can will work and look OK. It will not be a perfect match.
For a "perfect" job, after you are done, have it powder coated and baked on.
3,842
You need to remove any oils that are on the new steel. I would wash it with Simple Green on a hot sunny day, and then put it out in the sun to dry. Then put a self etching primer on both sides, and let it dry for a few hours, then spray with whatever paint that you want to use. I advise against powder coat, since if it gets a chip in it, then water will get under it and rust. There are some industrial powder coatings that don't crack and are chip resistant, but those are more expensive than the run of the mill powder coatings.
OrangeKrush
Nov 15, 2020
1,047
514
Indy
If painting.. I would sand or steel wool the existing painted part before applying new paint.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
Red scotch bright... Rattle can will peel off of shiny kubota powder coat. Take a stroll around the dealer lot to see touch-ups gone south. I would suggest catalyzed factory paint.
