How much prep befor painting wheel weights?
phaser
B7100HST 4x4, FEL, field mower
Aug 6, 2013
171
Oregon
I found a set of wheel weights that are currently painted white.
Outside of washing and degreasing is there any more prep I should do before spraying the Kubota Orange?
11,025
If any paint is missing or if they are sun faded a quick coat of primmer wouldn't hurt to make the new orange bond well! ;)
Orange Tractors
Jul 19, 2009
323
Butler, MO
Depends how long you want this paint job to last, and how good you want it to look. A good prep job can make even cheap paint out last the most expensive paint with a poor prep.
I would at least scrape and or sand any rust, if you don't use one of the newer rust converters on it.
Also, slightly rough up the existing paint before putting down a good primer coat, then spraying the top coat.
I don't mind painting and don't mind doing prep work; but I expect to paint my own equipment one time only.
Robert
phaser
Aug 6, 2013
171
Oregon
Thanks Robert
These weights are in pretty good condition paint wise, with just a few spots of rust about the size of a pencil eraser here and there.
