Hi guys. I finally got a bit more free time to play with the tractor today. I decided that as I gave it a basic health check when I got it the next important step would be to have the cutting deck apart and check that's ok (up until today I'd only given the main engine and gearbox a once over).
As it turned out it's not too bad. No major corrosion, but I did snap off one of the belt cover bolts. It didn't even feel that hard to undo but it sheared. Maybe a dodgy bolt or something, I was really surprised when it popped! Once I was inside I found a right old mess - it's not been cleaned out for a long time that's for sure! The belt looks badly worn and the blades also could do with a sharpen (I've used sharper strimmer line!).
My first problem that I can see is finding out which deck it is? Kubota list the RC44-42 or RC40-42 as standard fitment. As I need to get a belt (and I assume they are not the same on both) I need to know which it is. I've taken some pictures in case it's obvious, but a lack of Google images has left me coming to you guys for help. Do you recognise it?
If anyone does know which it is I'd be really grateful if you could post up a reply. I'm off on holiday tomorrow and I'm not sure if I can read my PM's on my phone so a post here will enable me to look up a part number and get it ordered ready for when I get home!
