Hour Meter
OW Douglas
B2920
Jun 6, 2014
15
Altoona, Pa, USA
This may be a stupid question, but has anyone ever checked the accuracy of your hour meter? Mine (b2920 with 11 hrs) appeared to me to be off, so I ran it at idle and it took 13:23 to change over 1/10 of an hour? More than twice the expected time! Any thoughts?
6,633
OW, maybe the hour meter calibrates it's self to the time zone it's working in and you just have LONG days in Pa.
Actually, I think the engine has to run at like 2000 RPM to read accurate. It more or less measures how hard you work it, not how long it idles.
OW Douglas
B2920
Jun 6, 2014
15
Altoona, Pa, USA
Thanks for the info D2. Some days seem very long, if you know what I mean. It makes sense now, the hour meter acts more like a tach timer. I've learned something for today!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I have seen some hr meters that run off the engine oil pressure and others that are simply either on or off with the ignition key. I've never really watched mine that close but it seems to be fairly accurate when I'm working.
UnionMan
M5-111HDC12, L3800 HST , RTV-X1100C, SCAG TigerCat 61" Kawi FX Motor
Aug 21, 2013
104
Warrenton, VA
I know on mine, L3800 it its calibrated by RPMs. There is a cable that runs from the hour meter to the front of the motor on the fuel filter side. The speed the cable turns is in relation to the motor RPMs. I found this out when I was pushing snow last winter and had the metal line snap and had it fixed under warranty at the dealer.
