homemade grill ??
GeoBx2680
FEL, 60" mower, 60" plow, Pallet Forks, 50" snowblower Front mount
Oct 8, 2018
87
Mn USA
So I got a 250 gallon tank I want to make into a grill/cooker/smoker maybe
My question is whats the best style to cut it open to make it hinge.
Pictures are helpful
Trying to get some ideas
Thanks
torch
Jun 10, 2016
2,755
976
Muskoka, Ont.
Cut the hinged side first. Weld on the hinges. Cut the rest of the opening.
(Or were you asking what to use to cut it? )
8,904
If it's a 250 gallon propane tank, please fill it with water to the top first then cut it open! ;)
GeoBx2680
Oct 8, 2018
87
Mn USA
I'll keep this in mind. I was hoping to cut it with sawzall if not.. got a torch at work.
torch
Jun 10, 2016
2,755
976
Muskoka, Ont.
Its a fuel tank out of my basement. I switched over to propane
There will be residue and it will be ignited by the cutting tool. Start with that assumption and go from there: work outside in a suitable location well away from combustible materials and ground cover, make sure the tank is not sealed so pressure cannot build up, have a means of extinguishment at hand.
3,108
Back in the day, I repaired a lot of old LandCruiser gas tanks- they had a common problem with poor solder joints, especially on top. I removed & drained them, dried them with an air hose for a half hour or so, then used a flex radiator hose to connect their filler neck to the tailpipe of an idling vehicle. Then I re-soldered them with an open flame torch. No boom.
