help with gas gauge on a T1460
beachbumtroy
t1460
Nov 20, 2024
10
crystal river,fl.
ok i just got a T1460, and i got it running got the deck fixed, now im wondering about the gas gauge and
wiring? it has some litebulb holes in the dash but thats it, so i was wondering how to fix? the easy way is i see they have an updated gas cap with float built in but its a little pricey....so im hoping for some good advice where from and how to run line from gas tank,im assuming its an electrical gauge,couldnt find anything about it in parts list or owners manual? thnx in advance for any and all ideas....p.s im no good with electrical diagrams :)
5,592
curious, all I can find is that cork on a stick gas cap for $150+-
I'd have to see pictures of your current float/meter setup.
I did install an aftermarket unit in my forklift,worked fine for years....
5,592
OK, that makes the 2 drawings I see online make sense ! one...no guage, 2nd has 'option' of fuel cap gauge. Reminds me of the one in the Ford LGT125 series and some CASE GTs.
beachbumtroy
t1460
Nov 20, 2024
10
crystal river,fl.
yep that sounds like the bottom line.....ive never had a mower that at least u could tell the gas amount by the tank peeking thru somewhere? ......so it looks like im going to go with the fuel cap float gauge, found one at messicks for $101. which is ok just never heard of a mower u couldnt tell fuel level somehow? thnx for comments, was thinking after i posted that litebulb holes wouldnt have held a gauge anyway :) thnx
8,546
Measure the depth of the tank:
Then send me the $90 you save. ;)
8,546
wow that sounds fantastic, i just emailed them to find out about the 2 1/4" id and 7 inch depth one? thnx and yes u deserve a tip........see ive seen those things years ago, but did not remember to look up:) disadvantage of being old. thnx again
If it's the wrong size PM me and I'll point you to the right size.
