Help me out here...
Realtor
BX2380
Mar 19, 2024
19
26
Pensacola Fl
I've searched the Kubota sites. I can't find the weights of the following:
344 loader
54 inch drive over belly mower.
supposedly the BX2380 comes in at a weight of 1,433 Lbs.
I'm trying to figure out the total weight with the tractor, loader and the belly mower.
Thanks,
Jim
Bearcatrp
Mar 28, 2023
1,129
752
Minnesota
The 344 seems to be 132 lbs
ken erickson
Nov 21, 2010
1,338
2,375
Waupaca Wisconsin
I think that 132 lbs is the bucket weight. Loaders net weight 478 lbs according to Tractor data.com.
kubota-la344-specs-review
Realtor
BX2380
Mar 19, 2024
19
26
Pensacola Fl
thanks, I was on that one site, I just didnt read far enough.... Thanks, I also saw a page just now that said the 54 inch driver over was 210. that puts the tractor and all at 2121 lbs. I have a 3,500 axle trailer that gives me approx 1,380 for the trailer itself, and I don;t thnk its that heavy. thanks all!
5,187
IMHO,.....too close for comfort!
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
444
369
Nazareth Pa
Shovel, Shovel, and Shovel some more. 2 loads (total of 2 Tons) in one day.... Good times
How about drive up on trailer and use tractor bucket to unload ?????
Bearcatrp
Mar 28, 2023
1,129
752
Minnesota
I bought my 1880 to shovel. Screw hand shoveling. Use your tractor to unload before taking it to the dealer. By the way, unless you’re planning on leaving it attached, may go get it and put it on yourself. Got to learn sooner or later. I put mine back on for the 1st time a couple weeks ago. Not to bad.
Realtor
BX2380
Mar 19, 2024
19
26
Pensacola Fl
I'd like to get a little training, I do plan on leaving it attached during the summer months, but may remove for the winter months
Bearcatrp
Mar 28, 2023
1,129
752
Minnesota
check out the you tube videos. Better than reading the manual.
WI_Hedgehog
Apr 24, 2024
1,105
1,593
Milwaukee, Wisconsin, U.S.A.
The mower manual is quite detailed and explains every step in both words and pictures. I thought it was easy to get the mower on and off if following the procedures in the manual. I both removed and installed the mower on concrete and turned the deck wheels (per the instruction manual) to roll it out and back in which made it roll easily. The hard part was getting the PTO shaft to release my first time doing so as the previous owner "never" removed the mower and the shaft grease became thick.
4,727
Shovel ohh thought yinz was talkin HD's
Realtor
BX2380
Mar 19, 2024
19
26
Pensacola Fl
I'm getting the drive over mower deck. I might not drive over it to attach and remove, but I'm not getting younger either.
WI_Hedgehog
Apr 24, 2024
1,105
1,593
I read here and saw a few YallTube videos saying the drive-over deck had some issues...just passing that on as I know no more than that.
I'm pretty close to retirement age, have a bad shoulder, stretched pinky tendon, bad hips, one bad knee, bad neck, and a bad back. (Sure ain't goin' to the grave "unused." 😂) That's why I "do the mower thing" on level, smooth concrete. Just passing that on....
