Hello. I have a b7800 needs a battery
3,058
Tex,
this is much like oil and grease and women's hair color ............ aint no real perfect answer, I prefer brunettes, does that help? Ok - kidding.
Measure the phyical size of your battery ..... LxHxW and note the terminal directions ..... some batteries DO switch the poles (most have a R behind the number series) - then go to where ever you wish to buy a battery, and get the largest CCA you can afford and place that in the tractor. And buy a "good" battery maintainer to boot. AND you should be happy for ........... 5-10 years! maybe.........
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Like hokie said, battery threads like oil/grease threads…
55B24L is the JIS (Japanese Industrial Standard) rating for batteries. Its converts to a 51R (BCI group rating) we use here in the States. Pick what you like in that group for a drop in replacement.
I don’t know the specific tractor and battery location/mounting area. You can go measuring size and maybe get a “bigger” battery just take into account battery cables and post orientation.
CharlesB7800
B7800, FEL, Bush Hog, Post Hole Drill, 4' Box Blade
Aug 24, 2019
York County, SC
I bought an Interstate 51R 500 CCA battery in 2001 or 2011 and am just now deciding to replace it (after I add some distilled water and try charging it up again! Your Experience may vary, but since you asked I decided to share my experience. I also own a B7800 Kubota.
5,187
Response to a nearly three year old post?
