Headlight Wiring Harness Question
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
258
47
Sandpoint ID
www.gemstarcustoms.com
Been doing some Spring Fixies on my L3600
I replaced my Headlight Blubs, which I actually found on amazon for $2.99 each for Hella's shipped..
But I started wondering about these two wires
Does anyone have a guess as to what the two leads are coming off the headlight harness might be there for ???
I tested them
Negative & Positive 12v
Goes hot with the key switch
Looks to be about 18ga so light duty
My first thought was Aux lighting but they would be Always On with the key
Thoughts
5,358
My guess.....running lights.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
It's hard to see the colors on the wires so see if you can trace it yourself.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
585
251
CNY
The wires look light blue and black in the pics so should be air filter lamp. Easy enough to check, short the wires together and look at the dash.
By the way my L4310 has basically the same configuration in the harness and that's what they do on my tractor
11,054
The switch was under the bottom of the elbow.
whitetiger
Nov 20, 2011
3,682
2,096
Kansas City, KS
so.... some 'idiot light' comes on when air filter is plugged up ( restricted ) ?
Curious as wire don't seem very long....
The wiring only needs to be long enough to reach the air filter switch on the air filter housing.
