Loose hazard lights due to branches, vines when mowing. From the scrapyard found a piece of stainless steel 5.5” x 1/8” tubing. Back at home cut two 2” rings. Drilled 1/2” hole for lamp bolt. Had file the hole slightly and remove one lens to install the light fixture. Fine sanded to bright statin finish.
