I'm gonna agree with everyone saying to evaluate the application. If you're getting it for farming or higher volume timber work where you go in straight lines or on roads for extended periods, yes a Gear drive or Shuttle drive is going to work best and create a lot less heat and be a lot more efficient for fuel use. If you're going to be doing landscaping, dirt work or anything similar that requires low speed/high torque and constant direction changes, rocking a pedal back and forth is a LOT better than constantly reaching for a lever. I got mine for the latter purpose, and having grown up around 8N's, Farmall's and MF-135's, hands down, working in the woods is a lot better with HST.
Just give some thought about what you're going to be doing most with it. If you will only be maneuvering in tight quarters, there's no substitute for HST. Open fields are a waste of fuel with HST, but the HST can save a ton of fuel and time by eliminating all the shifting of a manual when constantly changing directions. If it's maneuvering a backhoe application, shuttle shift might be better if you're digging long trenches, but HST might be perfectly suitable for more accurate positioning of the machine. Hands down, a manual is far better for tilllage or haying where constant speeds in one direction are needed for long periods of time.
