Atlanta Panther
Kubota L3200HST with Loaded R4 Tires, LA524 Loader and Quick Connect 66" bucket
On my L3200HST 4WD the manual says to remove the breather plug when greasing the front axle support. The plug is one of the square head bolts and I can't get it out. I seem to recall someone saying that the axle could be under pressure. Is that possible? Or should I just squirt some bolt remover in there to try to loosen it up to remove it? I need to finish my grease job.
