Greasing a woods Rotary cutter
SGut3
Woods Brush Bull, LA 480 Loader, box scrape, Tiller, post hole digger, plow,
Jun 2, 2010
Va.
Can anyone reccomend a grease gun with flexible hose or an adapter that will allow me to grease the universal joint on my 5 ft woods rotary cutter? My gun has a flex hose but the nozzle and crimp on the hose are about 3 inches long and will not negotiate the turn to grease the rear universal.
Thanks,
SGut3
Sam427
L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Nov 6, 2009
194
Snellville, Ga. USA
A standard grease gun should do it. Take the driveshaft loose and lay it down if you haven't tried that. It's hard to believe you can't get to it from some direction, I have a Woods 5' and I grease mine.
SGut3
Jun 2, 2010
Va.
Sam 427,
What are you referring to when you say lay it down? Take it loose from the gear box entirely?
Sam427
Nov 6, 2009
194
Snellville, Ga. USA
Sam 427,
Either take it loose from the gearbox or the PTO, then you should be able to move the u-joint so you can get to the fitting.
eddie
96
ottawa ontario
I've got a small pistol grip type grease gun with a flexible hose that just barely makes it to the grease nipple on the universal of the U-joint and if you got long skinny fingers and can swat the flies with your tail its easier. But not too easy.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Go to the store and buy a small box of grease fittings and get one's that have a 90 degree elbow on them.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Thanks,
SGut3
This will fix what you right up. Works like a champ. If you can get a straight shot at the ball on the fitting this will grease it. It just slides straight on and then locks in place. I ordered mine from www.thetoolwarehouse.net for about $9.
