Grand L
Scorobe2916
L3560
Dec 12, 2017
Union, MO
Does anybody know of a kit to reroute the hydraulic hoses for the Grand L series tractors? The hoses are precariously hanging of the side of the loader. This is aside from the fact its ugly and makes the loader look like an after thought. Or is it a DIY job? Previously owned a B3000 and the loader looked clean on it. Thanks
Tweetybrun
L 3200 Tractor Loader B/H RTV x1100c Grand L 4060 FL 805, BH 9.2
Jul 28, 2014
71
Hancock New York
Mine look pretty neat. I was trying to attach a photo but I am having a problem doing so. I’ll put it in my album.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,522
550
You know...I have seen many pics of Grand L's and that is one thing I have noticed.....some have the hydraulic lines tucked in and neatly run and others had them sticking way out like you describe?
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Here is how mine came from the dealer. I have had no troubles, but then I don't need to go inthe woods.
lddykstra
L3940HSTC
Feb 5, 2014
23
Rock Valley, Iowa
The 40 series has the hoses tucked between the tractor and the loader frame. The 60 series has the hoses outside of the loader frame. If you have a 60 series and want to reroute your hoses, maybe you could get some ideas/parts from the 40 series?? My guess is that they made the change to make removing the loader easier.
Technical Ted
L3560/cab LA805 loader LandPride RCF2060 rotary cutter, HLA hyd angle snow blade
Jul 2, 2016
105
Dansville NY
Which loader did you get on yours? I've got a model LA805 as does Sheepfarmer and my hoses are mounted similar to hers as well... nice and neat.
Ted
Scorobe2916
L3560
Dec 12, 2017
Union, MO
I did get the 805 also I just don’t know why they couldn’t have routed the hoses on the inside of the loader arm. I’m sure it’s cause it makes it easier to get at the couplers to remove the loader. It just seems like they’d be more susceptible to limbs. Realistically I doubt anything would happen and I’ve considered just making a guard to help protect them which would be far less expensive than new hoses.
Scorobe2916
L3560
Dec 12, 2017
Union, MO
Guess if that’s my only gripe about the tractor I should be happy. Nice step up from my B3000, which I had zero complaints about other than its limited capacity.
conropl
L3560 HSDC
Oct 17, 2016
233
West Michigan
I got a L3560 this last spring with the LA805 loader. I did not like how the fittings are sticking out either. Dealer said the were to many complaints that it was to difficult to attach when they were inboard. I have not run into any issues yet.
I just got the L4479 front snow blower, and they put a second set of fittings for the blower and they are mounted inboard of the loader. So it is possible to relocate the fittings inboard of the loader without interference... but I have never looked at the hose routing interference. Basically, maybe you could use the blower fitting kit.
Sent from my SAMSUNG-SM-G870A using Tapatalk
