Grab hook location question
Steve A.
L48
Nov 24, 2014
14
El Dorado Hills, CA. USA
Hello,
I'm looking for idea on where to mount/weld 2 grab hooks on a kubota 1747 bucket. The bucket has a round top edge.
If I drill the bucket to bolt on backing plates should I put a plate inside the bucket also?
Will 1/4" backing plates be sufficient?
Anyone done this or seen it done? Any help is appreciated.
The bucket is attached to a L48 Kubota. See pics.
2,170
Hello,
Try to place the hooks where the bucket is connected to the tractor. I would bolt rather than weld, bolts are on a plate and can be stronger than the metal at the weld.
Hooks on the far edge are fine but should be more along the inside - and always pull straight and not at an angle. Angle will cause a tipping problem!
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
Kennyd4110
Vendor Member
Sep 7, 2013
1,171
336
Westminster, MD
www.boltonhooks.com
Thanks for the referral guys!
Those HD round back buckets present a problem for out bolt on hooks, we always recommend welding them onto those style buckets-and yes 1/4" plates are more than adequate.
