Golf Ball Technology in Diesel Engines
mikester
M59 TLB
Oct 21, 2017
3,842
2,468
www.divergentstuff.ca
Magic foo foo. Painting flames on the side of your truck makes it go faster. Bigger rear wheels save gas too because you are always driving down hill.
johnjk
Apr 13, 2017
1,598
1,582
West Mansfield, OH
Interesting read. The latest in people trying technology to get more out of the old engines. Anyone remember the company that sold the metal inserts that went in to your air intake to make the air swirl in a vortex as it entered the combustion chamber? I could see the dimples working just a bit better. Better fuel air mix/suspension, better compression and better HP/ emissions.
Now who will be the first to go out and drill their pistons on their Orange to experiment?
johnjk
Apr 13, 2017
1,598
1,582
West Mansfield, OH
for those of you looking for quick HP gains, remember painting your calipers red is good for at least a 10hp improvement
3,363
5,602
re: Anyone remember the company that sold the metal inserts that went in to your air intake to make the air swirl in a vortex as it entered the combustion chamber?
they still do ! came out of a 2001 F150...one day I may install in my '97 F150
3,363
The best way to get maximum power is to increase the amount of air/fuel passing thru the internal engine at the fastest rate possible. This would be an axial-flow/ram-jet such as the SR71. No golf-ball dimples on that one that I observed in the times I’ve had hands-on it… oh…wait… what’s those little holes at the aft containment-ring…? LOL
5,432
2,128
couple somewhat well-known cylinder head porting guys have found some success in "golf-balling" the intake ports. But it comes at a cost. 15hp for another grand worth of work. The majority of people don't go for it and I don't blame them, when you can make 15hp for a lot less money.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
The extra HP would be 'FREE', if they didn't spend all the money on useless, unneeded 'electronics'.....
My car has four less cylinders, more than twice the horsepower and double the mpg than the old man's V8 Model A. Electronics had a lot to do with those improvements.
William1
BX25D
Jul 28, 2015
1,204
402
Richmond, Virginia
Race engines are dimpled on the intake ports all the way to the butterfly. Intake valve to on the port side. Really not too hard to do and does not have to be any CAD alignment. Just touch the burr a lot. Adds 15 minutes per port and valve.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Adding golf ball technology seems to be a great way to attract water into the cylinders….
6,678
Found water with a lot of golf balls. Good thing I gave the game up.⛳🏌️‍♂️
Sorry for the tangent on diesel engine construction....
I've "witched" water well locations quite a few times. My Grandfather taught me.
Just used a small forked branch from a tree nearby.
My Grandfather recommended apple. I practiced on our farms 50 years ago.
Friggin' thing would "point" to spots....
One of those I witched now produces the water to my house, and 600 other connections in my village. Capacity was estimated at 2,500 gpm, but designed at 500 gpm or so.
I'm a scientific person. Don't believe in it, but it's worked multiple times.
Go figure?!?! :unsure::unsure:
5,432
2,128
What they found was that dimpling does 3 things. It causes more surface area in the port, leading to "skin friction", it gives the port more places for cracks to propogate, and it "can" allow more power-although the gains are typically not really worth the R&D it takes to get it right. There is a reduction of "base drag" or "base friction" but the percentage of CFM and horsepower improvement was not significant enough to warrant mass production--at least not at the level we were messing with it at. Some guys wanted it and so be it, we did it for them and it cost more. Similarly the guys who were using Jager's connecting rods, they wanted them and they paid (dearly) for them. There wasn't enough advantage to justify the troubles. Then some things got "outlawed" (sanctioning body rulings), in order to "control costs" which usually works the other way in professional racing. They just find more (and often more expensive) ways to bend the rules.
