On an old B7100 - key turns left to send power to the glow plugs
I recently replaced some wiring from my ignition switch to headlights, horn and glow plugs, previous owner had done some shody wiring modifications for reasons unknown. I noticed after replacing the wiring that my battery is completely dead after running the tractor for anything above a couple of minutes. Upon further investigation I found that the glow plugs are getting power while the key is in the on position. I checked the power on the back of the ignition switch assuming that I had done something wrong. After checking each terminal on the ignition switch I do not have a terminal that is powered when the key is turned counterclockwise (preheat position) but NOT powered while the key is on. I am assuming this is not correct but wanted to double check before I replace the ignition switch.
EDIT
Looking at the wiring diagram I am confused by the wiring of the glow plug indicator in relation to the glow plugs. Can someone explain?
EDIT
