Glow Plug Use After Starting
miro
snow blower
Feb 23, 2014
62
toronto
Now that the cold weather has started , I wonder about using the glow plugs after starting.
I have a 25 year old B5100 - 2 cylinder.
I usually count 10 clicks on the glow plug timer and make sure I can see the glow plug indicator is glowing.
It usually starts firing on 1 cylinder and making white smoke.
Then after about a minute ( maybe less) , the other cylinder starts firing, and I'm good to go.
I've checked both glow plugs and the wiring - they are good.
So, would it damage the glow plugs, if I activated them AFTER the engine has started up to encourage the second cylinder to fire?
miro
1970cs
1,124
Grand Ledge
No since the old glow plugs are not the quick glow style. You can hit the preheat again to help put heat in that cylinder quicker.
Pat
3,300
I do it often on cold weather start-ups with my B7100. Really smooths it out quickly.
2,908
Might try holding the GP's on for 20-30 seconds before first try to start. May find a big difference!
My two B7100's will not start at all without a little warming, summer or winter.
I glow them for 3 clicks of the hours meter! Which is about, 8-10 seconds. Much more in the cold. I agree with D2Cat, mo glo, better go!;)
