K Kranky New member Apr 5, 2016 5 0 0 USA Apr 6, 2016 #1 What gear type is used in the final drive on the BX series and the GR2120-2? Helical, Spur? Thanks
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,429 8,720 113 Sandpoint, ID Apr 6, 2016 #2 The BX doesn't have finals, axles are direct driven via differential. The GR2120-2 has strait cut finals, but not a geared differential (slip diff). Curious to why you ask? Last edited: Apr 6, 2016
K Kranky New member Apr 5, 2016 5 0 0 USA Apr 6, 2016 #3 Thanks for your reply. I was doing comparisons with the JD1023E. That unit has a spur gear for the final drive. I thought I saw somewhere that Kubota used a helical gear. I can't find that reference again. Cheers
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,429 8,720 113 Sandpoint, ID Apr 6, 2016 #4 The BX uses a helical gear on the differential.
