Gears for final drive?
Kranky
What gear type is used in the final drive on the BX series and the GR2120-2? Helical, Spur?
Thanks
8,745
The BX doesn't have finals, axles are direct driven via differential.
The GR2120-2 has strait cut finals, but not a geared differential (slip diff).
Curious to why you ask?
Kranky
Thanks for your reply. I was doing comparisons with the JD1023E. That unit has a spur gear for the final drive. I thought I saw somewhere that Kubota used a helical gear. I can't find that reference again.
Cheers
8,745
The BX uses a helical gear on the differential. ;)
