Have a B7200E (2wd, 8-speed stick, front mount PTO) that has a 60" 3-blade deck (RC60-72A mid-mount-mower).
I picked up some Kubota-brand blades (Part number 70000-25006) and they fit perfectly (obviously as they are the correct Kubota number).
The blades are 2" wide, 3/16" thick, 20-7/16" long, with a 23/32 diameter hole.
I've used the Oregon Gator Blades before on my old Husqvarna push mower, and my dad has some Gator blades on his Kubota. In both cases, the blades cut phenomenal, much better than stock.
Oregon use to make an OEM style blade for my tractor, part number 91-429, but was discontinued in 2016, and isn't much help anyway as is it a stock-style blade, not a Gator style.
Using the online catalog, and looking at the blade specs, I did find one that was very similar. Part number 96-319 is 2-1/2" wide, .203 thick, 20-1/2" long, and has a 5/8" hole.
I'd have to open the hole up to the correct size, and may have to kiss the ends if the length is an issue (I doubt it will being only 1/16" longer).
Does this sound like this would work? Or am I asking for trouble by modifying a blade like this? I'd obviously have to make sure it is balanced so I don't wreck any of my spindles / bearings.
Thanks!
Thanks!
