G6200 front pto half shaft for snowblower
dleblossom
G6200 lawn tractor, G2538A 2 stage snow thrower. G2001 snow blade.
Nov 10, 2014
Saginaw, Michigan,USA
Hello, this spring i aquired a G6200 with a 48 in mowing deck. through endless searching i was able to locate and purchase a g2538a snow thrower and subframe. it came with everything but the male half shaft that connects to the tractor front pto. im not a machinest but as much as i can tell the shaft is 1 inch in diameter and has 10 splines. kubots wants 520 dollars for the complete shaft (male and female sides). they say they cant get half shafts any longer. is there anywhere that sells this aftermarket or makes and adapter to get to an 1 3/8 standard 540 shaft? much thanks in advance!!!
dleblossom
Nov 10, 2014
Thank you for the reply. I'm needing the entire male half. Looking at the schematic, it's all the parts you see for the bottom shaft. I did find an aftermarket adapter that's 31/32 ,10 spline female to 1 3/8, 6 spline. I'm hoping that will allow me to use a more common male shaft from tractor supply?
