G4200 HST Help Needed
kajun
M4700 ,G4200
Mar 28, 2017
St Francisville , La 70775
Folks:
This tractor is outfitted with an Eaton 11 or perhaps Eaton 1100 HST Transmission . This is way above my pay grade so I turn here for help . My mechanic [ an independent and a fine fellow ] says that the Eaton Pump and the transaxle case appear to be a single unit and that to remove the pump requires removing the transaxle case too . The Eaton manual that some one here kindly provided a couple of years ago doesn't show that to be the case .
The Messick's schematic for the transmission seems to confirm my mechanic but the Shop Manual kindly provided by Messick's seems to suggest the Eaton Pump comes out separately . Do any of you know or have an opinion ? Here is the Messick's drawing :
This baby backs up just fine but won't go forward . So I want to take it out for rebuild at an Eaton authorized shop . If it comes out without the transaxle case the job is simpler and transport to shop is easier .
Obliged for any help .
10,894
4 bolts to split the HST from the Rear end, it's not all one unit.
kajun
M4700 ,G4200
Mar 28, 2017
No , just gradually got worse and worse . Due to wife’s health , machine was used only once this season and , once fluid was hot , just stopped pulling ahead altogether . But I would like to hear your thoughts . Thanks .
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
199
94
Fayetteville GA
I have a axle leak on mine and forward gets sluggish before reverse when the fluid gets low. A little air in the system and it starts acting up. Will the wheels roll forward with the rear end off the ground? Fluid level good?
kajun
M4700 ,G4200
Mar 28, 2017
Fluid levels are good ; no leaks that I can see ; fluid doesn’t diminish over time - if so , very little .
Problem developed over two year period . First pulled slow ahead on slight incline . Than gradually worsened so that now doesn’t want to pull ahead at all . I haven’t tried raising wheels to see if will pull ahead with no load at all . Yesterday in mechanic’s shop on concrete , all it did was make the slightest movement forward and whine .
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
I gave a copy of the workshop manual that explains the function and overhaul in detail but I don't think I can post a PDF file that large here.
