G1900 will no forward or reverse
Blue68
Oklahoma
I am looking at a G1900 with 612 hours on it that parked around 2004. I put a new battery in it, oil and it started right up..... needs a new seat and blades.
When I press the pedal it would barely move forward or backwards and makes weird noise. I am able to move the deck up and down with no problem.
Does it sound like something major and tractor worth $500?
9,881
Could be several things, they could range from cheap to expensive. ;)
Pap
BX2360 G1900
Feb 12, 2015
45
Middletown, pa
They are known for drive shaft problems. There is a bolt or a pin that holds the drive shaft to the transmission. This bolt or pin can brake or fall out then it won't move. The drive shaft moves forward off of the transmission splines when this happens.
badmaxdog
G1800s B2920
May 2, 2015
Natrona Heights, Pa
I would agree that it is probably a driveshaft problem. I just replaced mine on a G1800. New driveshaft will run you about $400 for the part, if that's your problem. It is a very common problem with the G1800, G1900, and G2000.
