L3560 front fuse box. Just in front of radiator.
The battery was replaced. The connections were placed wrong. Neg to pos / pos to neg and the tractor was attempted to be started.
The 80 amp and 60 amp fuses, 1 &2 from left to right were blown.
‘When I puled the fuses the prongs on them remained in the fuse block. I have tried to pull them out with pliers with no luck. Pulled reasonable hard. Also, I could not pull the fuses by hand. Again I used -pliers to get them out.
‘Has anyone had this issue?
I’m afraid the prongs may be welded in. I do not see a way to disassemble the block, but I haven’t removed it yet..
