Fuses for L1500
bucktail
Jun 13, 2016
1,297
220
MN
Has anyone needed to replace the fuses on one of these or anything that needs the same fuses. I've never needed to but it seems like something that I should have on hand. I keep forgetting to ask every time I'm at the dealership.
The fuse box cover is missing as well so if anyone has fabbed one I'd be interested in pics.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
The fuses are not Kubota specific. You can get them from any auto parts seller. You can make a note of the existing fuse values and pick up spares just about anywhere. Honestly I've never blown one, though.
3,082
Get the cover for the L185 and it will probably fit.
it is rectangular with a knurled screw in the center. Fuse box has 4 or 5 fuses
I can probably provide you with a part number if you need it.
3,082
Some of the older tractors had odd wire type fuses but I believe that the standard glass fuses (like older 50s to 70s) cars used may fit
(after next post was done I see they won’t work)
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
These are the correct fuses for a L1500/L1500DT
AKA, L175, L225, L225DT
I only show a P/N for the 5A;
34150-33620 FUSE 5A
The larger is a 10A fuse
This is the correct cover,
3,082
Here is the one on my L185 that has the newer style fuses
part number 37150-33600 about $50 for the cover and fuse holder both
0378BDB9-6995-4938-B428-9D013983FAC4.jpeg 83239AF5-E0F0-4DED-9AA8-2FF0AF18B60D.jpeg
3,082
One for headlight low beam
One for headlight high beam
One goes to the regulator then to the lights in the gauges
One is for accessory like horn
Then one in line fuse for flashers (optional)
