fuel stop solinoid
Dr chops
V1505
Dec 24, 2020
26
New Zealand
hi
i had to replace my fuel stop solinoid the other day becasue it over heated and let go. do they have an interal timer or do i need timed relay?
cheers
lucas
8,728
You'll need to be way more specific as to the exact solenoid and use, as there are two styles of stop solenoids and with those two styles there are 2 ways to run each of them.
Dr chops
V1505
Dec 24, 2020
26
New Zealand
Ah I see it’s a on a v1505 engine it has a 2 terminal plug. I can’t see any numbers on it. On the bench the pin is out and retracts if pressed
Cheers
Lucas
8,728
Pictures of it and it's mounting location should give me what I need to be able to give you the right answers on what's needed to drive it.
