Fuel Filter Leak at exit elbow
3,637
My M4700 has the paper fuel filter with the plastic sight-bowl and paper filter. It has a shut-off lever which does not work. (The fuel cont'd to flow when I opened it up to clean the filter. Made a mess.)
Anyway, cleaned the filter etc.
But the problem I'm really posting about is that the exit elbow which has a rubber line to connect to the fuel injector pump "swivels" and easily pulls out of the cast aluminum top of the filter assy. It appears to be a "pressed-in" fitment.
Anyone else experience this? How did you fix it? Buy a new assy...only to experience it again?
I'm thinking of clamping off the tank-to-filter line and removing the filter assy, drying it thoroughly, and using JB-Weld to seal up that exit elbow. (I tried a small/thin O-ring and it won't insert and only wads up and doesn't seal.)
Just wanted to start this conversation and see what others have done/experienced.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
261
Jefferson, Ohio
Mine fell out when it was about 10 degrees and plowing snow.
It could not happen at a convenient time.
I epoxied it in and used it for about 2 years. It was still working.
I just replaced it to make me feel better.
rentthis
1,010
25
summerville,sc
I have had the same problem with a similar water separator. The fittings are a pressed fit. They get to where you can turn them or even pull them out. I have sealed them with JB Weld and it worked fine for a time. The engine vibration breaks the JB loose and the problem returns. Replace the filter unit and the problem goes away long term. Kubota redesigned the filters on the Kx-71. I had replaced several on KX machines. I don't know about your machine but they weren't really expensive.
3,637
Jeff and "renthis"... Thanks for your reponses. (Nickelplate, A pic would not really help in any meaningful way... a pressed-in fitting that leaks... looks not pressed-in when pulled out... and leaks look like dripping fuel except when they're only a seep and then they just look wet.... what would you gain by a pic of a leak?)
But if someone wants to see what the part looks like, see item 170 in this link:
https://www.messicks.com/ku/85704?sectionId=222199&diagramId=389144
I think I'll temporarily JBWeld it until Kubota can confirm they've changed the design. Otherwise, it might be easier to simply tap it and thread-in an elbow-fitting like they should have done in the first place. :{
3,637
Follow-up: The JB Weld solution seems to work fine 9 months later. (I used electronic cleaner to clean and dry it before applying JB Qwik Weld.)
