My M4700 has the paper fuel filter with the plastic sight-bowl and paper filter. It has a shut-off lever which does not work. (The fuel cont'd to flow when I opened it up to clean the filter. Made a mess.)
Anyway, cleaned the filter etc.
But the problem I'm really posting about is that the exit elbow which has a rubber line to connect to the fuel injector pump "swivels" and easily pulls out of the cast aluminum top of the filter assy. It appears to be a "pressed-in" fitment.
Anyone else experience this? How did you fix it? Buy a new assy...only to experience it again?
I'm thinking of clamping off the tank-to-filter line and removing the filter assy, drying it thoroughly, and using JB-Weld to seal up that exit elbow. (I tried a small/thin O-ring and it won't insert and only wads up and doesn't seal.)
Just wanted to start this conversation and see what others have done/experienced.
