Fuel delivery problems on M8200
moesfarm
Fayetteville TN
I am having problems with my tractor. Sometimes it will just start smothering out and finally quit. Then it will not restart untill you loosen banjo bolt at injector pump. Then pump the fuel pump knob located on top of the fuel filter. You have to loosen the banjo bolt because the air will not bleed out of the "air vent cock".
I have just today cleaned and replaced the screen inside the "water seperator", changed the fuel filter, and drained the tanks. Everything was clean inside tanks. I then poured in 10 gallons of diesel and started it up and ran it up and down the road at 2000 RPM's it ran fine. I thought i had fixed it and then i went to put it in the shed and it quit again. What else could i check?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I'd start with the fuel line that goes from the tank to the primary filter. Also check the fittings that go into the filters. Known to get trash in those and plug them up.
whitetiger
Nov 20, 2011
3,341
1,762
Kansas City, KS
I am having problems with my tractor. Sometimes it will just start smothering out and finally quit. Then it will not restart until you loosen banjo bolt at injector pump. Then pump the fuel pump knob located on top of the fuel filter. You have to loosen the banjo bolt because the air will not bleed out of the "air vent cock".
I believe the first thing I would do is find out why the Jet Start Valve cock is not bleeding the air out of the system into the fuel tank. If a return hose or the check valve is plugged, it is a simple fix and needs to be corrected to keep the engine running anyway.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,276
178
Coyote Flats,Texas
Engine starving for fuel sounds similar to a M4900 I owned several yrs back. I checked several known fuel starvation problems but engine still would quit running after running for awhile. Local Kubota dealer service manager advised me to check for clogged small screen on water seperater cut-off valve. I removed valve to find clogged tiny filter,cleaned filter problem was solved.
country53
M8200 Kubota, M108S Kubota, JD 420C, JD50, IH 140, Deutz 4006, Deutz 6006,
Jul 2, 2020
10
Kentucky
My M8200 was doing same thing I found water separator unit had a blockage in it plus fitting was leaking allowing air to get in fuel system. Fuel pump was also weak maybe because of not being able to get fuel I replaced water separator, lift pump and fuel filter and it worked fine
cecilia.a.douglas
Kabota M8200 diesel
May 13, 2024
KY
where is bango bolt,,I have a M8200 parked tractor in shop 1 month ago, 2 days ago key will turn over but not ignite the engine, changed a very dirty water separator filter and the fuel filter, attempted to pump air out opening the air cock , battery full charge, but still the tractor is not running
9,869
Read post #4, you need to address the jet start valve.
