Had the same deal with the top link on the open station M9 I bought last year, one of the ends was securely locked tight and no amount of 'persuasion was going to break it free so...
I put it in my big bench vise, got the gas axe out, pulled the grease fitting so the hot liquid grease if any inside would run out, put a rag on the floor and heated it up. When the grease (what little there was inside) started smoking and running out, I figured it was hot, a put my 36" long Rigid aluminum stillson pipe wrench on the end (with an extension pipe 3 feet long (cause I'm a wimp) and cranked on it. Took a little bit reefing but it came loose. 6 feet of leverage is a huge amount of torque.
Ran it all the way out, applied new grease and a grease fitting and ran it back in and gave it a shot or 2 of grease. All is good now.
Heat is a good persuader. So is a big oilfield pipe wrench and a cheater bar....
Only thing I could think of was the original owner jammed the end in tight, couldn't get it loose, so left it all the way cranked in.
Not something you can accomplish on the tractor, has to come off and be dealt with in the shop.
And a good heavy duty vise securely bolted to a workbench that is securely anchored to the concrete floor too.
Replaced both grease fittings with new metric fittings with screw on dust caps I had in my parts box. I have a ton of parts laying around.
