Front Wheel Rim Broke
dchugg
loader, blade, tiller
Apr 29, 2013
Fallis, Alberta, Canada
I have an older grey market B1200. I broke the right front rim. The tire size is 5.00x12. It is a four bolt. There are no markings on the rim. Where can I get a rim and what is the actual designation for this rim? Are there alternatives I can use?
Gso125
L6060 cab and loader
Sep 16, 2013
81
The link he posted above looks to be the rim your looking for. I would just measure the center to center of the bolt pattern to double check. Good luck
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
The tire is fine, I need to find a replacement rim. Any suggestions?? Thanks
No, there is NOT another option for a direct replacement.
Unless you go my route............either way you'll be buying a new tire.
But you can spend 20 to 30 hours searching (I have) to prove me wrong.
4,695
Dawg goneit Murphy,, I do wish you would post a warning so I can put my sunglasses on when you post pics of that beast:cool: :D
hodge
Nov 19, 2010
2,959
535
Love, VA
Yea, they look fantastic. If I needed rims, there is no doubt the route I would take.
Pimping out the Kubota.
10,041
If you all notice lsmurphy only posted a link for a generic rim and not his tricked out rims!:p
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Here's the deal-
I suppose the OP asked around locally already about a used or new wheel, otherwise he would not be asking world wide where he could find one. The 12" 4 lug is no longer supported by Kubota,
He may find a 3.5" or 4" X 12" wheel but it will be a spoked trailer wheel and it will be 4on4, Kubota 4 lug is 4 on 103mm. The 4 on 4 will not work with standard lug nuts, nor will it mount to the Kubota hub without a 3/16" or 1/4" adapter plate (of which I never mentioned),
He cannot mount a 5" tire to a 5" wheel and further I'll bet his current tire is NOT OK.
His other wheel is probably NOT OK either, if one broke, you can assume the condition of the other.
You got a problem, now you need to come up with a solution. Most folks are spoiled, they think everything should just be handed to them........and cheap........or free.
You have a 20 to 30 year old tractor that is barely supported by the manufacture.
If you want to fix your problem you'll likely be buying new tires too.
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
369
9
Homer City, Pa.
Post a picture of your rim, I'll let you know if it can be repaired.
Big Kahuna
