Front wheel fell off
philkent
107
9
australia
The front wheel on my L345 just fell off.A couple of mechanical groans and off it came with hub attached.Havent even jacked it up yet.
What happened? phil
Update.......Ok jacked it up and have a clearer pictureThe bearings collapsed.Have looked at the parts book but cant work out what holds the hub on.Still have to get the old bearings off though .
hodge
Nov 19, 2010
2,938
501
Love, VA
What happened? phil
My dad had a gray market Kubota years ago, and the front wheel fell off. I can't believe that I had forgotten about that, especially as enamored as I am now with Kubota's. He was doing some loader work, and the front wheel just came off. In his case, the axle stub sheered off. This was one of those degrease and repaint models, which looked good but we really had no idea of its previous life. The dealer gave him another hub assembly off of a parts tractor. He sold it shortly after that, though, because it started leaking oil from the center of the tractor- probably a rear main.
Sorry that's no help for your dilemma, but I had to share that. I had forgotten all about it.
Pictures will help, if you can take them and share with us. Lots of smart folks here, and lots of guys who have had the front ends apart.
philkent
107
9
australia
All fixed. 2 bearings and 1 oil seal.Very easy job.How tight should the nut be?Sorry no pics due to tecnical incompetence.
bobkeyes
64
Corbin, Kentucky
I have never seen a wheel bearing from a Kubota, but have seen a lot of wheel bearings. If it is a tapered, or cup and cone, bearing, tighten the castle nut until very close to wheel lock up. Back the nut off one notch on the castle nut and insert cotter pin.
Hope this helps.
