Front snow blade and rear ballast
afret
L3901, MX5800, U55-4
May 7, 2015
167
North Idaho
I have a L3901 and will use a front snow blade mounted my FEL. Last winter I took off my backhoe to use the front blade. My rear tires are filled and I used rear chains. It seemed to work OK last winter this way but with the weight of the loader and front blade, is it safer to keep the backhoe on to put more weight in the rear?
8,490
Put as rear ballast box on it for the winter or a sand spreader. ;)
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
I usually have my grader blade on the rear. Comes in handy as well as rear ballast. I also have a sander, but only put that on when finished plowing as you don't want to leave salt/sand in the hopper, it hardens or packs and it is hell to get out.
bearskinner
Sep 1, 2014
926
241
N. Idaho
I find I can push snow with my adjustable blade much better without the backhoe or anything else on back.
afret
May 7, 2015
167
North Idaho
Thanks Wolfman and Jajiu for the info.
I noticed the same thing last winter after taking the backhoe off and didn't think about the weight distribution at the time. Maybe I should just get a 3 point ballast box in the back and put a few hundred pounds back there.
