I've had this happen twice now. The front drive shaft Part #K2561-16830 has a pin in one end and not the other, at least on mine and according to Kubota parts schematic. The one end has come off twice, even though it is a bit of a pain to get back on, even without the pin in. It seems almost impossible to have it fall off but it does. I tried drilling a hole through the Ujoint (easy) and then through the shaft to put a pin in both ends but drilling through the shaft is next to impossible - for me at least.
I'm assuming that the shaft needs a bit of play during operation, so I'm not sure putting a pin in it is a good idea but I'm stuck for any other solution.
I checked as best I can to see if someone prior to me had substituted the wrong shaft but everything appears correct.
With snow coming, I'm going to need the 4 wheel drive.
Stumped
- suggestions???
Stumped
