Front Counterweight Experience?
winesalot
163
Chelan, WA
I am picking up mt L4701 in a couple weeks and, this weekend, I am buying a 100 gallon Pak-Tank 3-Point PTO driven sprayer. The sprayer will put 800 lbs (potentially) of water plus the weight of the sprayer itself hanging off the back or the tractor. I will have rimguard in the rear tires and I plan on spraying with the front end loader removed. Any thoughts on the need for and how much weight in front counterweight I may end up needed?
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
I am curious as to the removal of the loader. It is the easiest and most convenient counter weight to the front end. Taking it off only to add another counterweight?
You can fill the bucket in seconds with sand, gravel or soil if necessary and off you go.
winesalot
163
Chelan, WA
Maneuverability in tight spaced vineyard rows.
bucktail
Jun 13, 2016
1,276
198
MN
According to tractordata.com, your new tractor will weigh a ton and a half and have over a ton of lift on the 3 point 24" from the pins. If you've got room to maneuver, the loader would probably make it steer nicer, but you'd probably be leaving it on if you did. I'm guessing you'll be fine with nothing up there. You may need to use the brakes to for tight turns and I'd do a test run in the yard if you need to road it with a full tank.
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
I'm with bucktail. I would see how it acts without any weigh first. If the front end is too light and you can't use it with the FEL, you can add a weigh carrier and suitcase weights on the front.
Bulldog777
L3200, RTA1266, Modern 5' BB, Mustang 60 FM
Jan 25, 2017
215
I know some will cringe at this, but you can raise the bucket up high and get your turning radius. With spraying you should be traveling slow, which will be safer. May not work in your situation, but it is an option.
Sent from my SM-G955U using Tapatalk
twomany
B7200
Jul 10, 2017
793
138
Vermont
I would put four 55# suitcase weights up front just because it makes good sense.
Loaders are always in the way unless you are using them.
9,578
The grape vineyards up here are not on flat ground, trying to run rows with the bucket up would surely tip a tractor over. ;)
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Wondering if what was meant was to raise it for turns only at the ends of rows? Still need for the turn area to be level. Or to spray in a pattern of every other row so you don't have to make 180 degrees all at once. However it still would be easier to ballast the front.
Grizzy3901
L3901hst, la525, 72" landpride finish mower
Jan 1, 2017
67
Bealeton va
You should be fine taking the loader off I had 1000+ pounds of lead on a 60 inch areator with the loader on and the front end was a little light but you have a heavier tractor with less weight.
