Front Axel
ferguson
L3130
Jan 19, 2022
319
124
w.v.
L3130 Just changed front axel oil switched to 80-90 gear oil drained a little from both sides when changing motor oil for a look see {Struck gold} changed front axel oil at 1000hr serv. used udt 2 did not strike gold at that service time . Don't know what oil was in it then as I just got it. Had 950 hrs . Struck gold this time very fine . Thats why the switch to gear oil. Think UDT TO LIGHT 1,165 hrs & two yrs "THOUGHTS"
2,832
Fergy - not sure what you are saying struck gold - hard to follow what you are doing OTHER than switching from one oil to another in your front AXLE.
8,764
S
Haved dumped oil into waste drum {dam} Was very light. Will run for a while & take a sample ?????
I'm thinking someone added something to the oil, or it was a modified oil, as I said I don't know of anything brass or bronze in that front end.
number two
B3030HSDC L2501HST
Mar 26, 2021
365
172
Northern Lower Michigan
Perhaps the OP is finding some of the "fines" left over from Kubota's machining processes?
Many have noticed metallic residue when draining the front axle,as have I?
2,832
I would hope after a 1000 hours - that axle oil had been changed a time or two! Shoot, at those 1000 hours it should have been changed like 3 times already! Then again we hear the stories of changing the oil filter - the original painted version at 400 hours too!
ferguson
L3130
Jan 19, 2022
319
124
w.v.
When I got the tractor it had 950 hrs & no history / Filters were not O.E.M. so it had oils changed / I changed every thing at 1000hrs including front axel / used UDT2 / was changing eng. oil so I pulled a little oil from both sides 2 quarts or so did not look at it untill after I finished oil change that when I noticed it very small amount with some metallic. / So drained all changed to 80-90 gear oil. Will run for 5 to 10 hrs operating & check. (Scratching my head if there something left in the drain pan ?)
