Fourche home made
Bmyers
May 27, 2019
3,624
4,908
Southern Illinois
Very nice job and inventive design. I had to use a translator since I do not speak French.
DownEastKubota
L5740, BX22, IH Cub Cadet 127 & 122, Several Gravely Model L's over the years
Dec 24, 2020
Maine
Very nice! très bel artisanat!
bmblank
Mar 4, 2015
774
494
Cadillac, MI
Just FYI, according to google translate
"useful for my portable sawmill"
4,189
Accolades!
3,394
What's the purpose of the bar going across between the forks?
Looks like if they were just bolted to the bucket sides where the bar is, the functionality would be the same, and the bar would not be needed...
Great result in any case!
Rejean
kubota l3200
Mar 3, 2021
Québec
[QUOTE = "Henro, message: 463225, membre: 38478"]
Quel est le but de la barre passant entre les fourches?
On dirait que s'ils étaient juste boulonnés sur les côtés du godet où se trouve la barre, la fonctionnalité serait la même et la barre ne serait pas nécessaire ...
Excellent résultat en tout cas!
[/CITATION]
Je boulonne les côtés quand je l'utilise pour mes bûches ou mes piles de bois, c'est plus solide, si je l'utilise pour différentes palettes, j'enlève les 2 boulons et ça devient ajustable
4,189
The bar KEEPS them properly spaced/aligned when they’re not installed in the bucket.
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
327
90
Bagley, MN, United States
According to French to English translator:
"I bolt the sides when I use it for my logs or my wood stacks, it is more solid, if I use it for different pallets I remove the 2 bolts and it becomes adjustable"
