For Kubota l2350 need injection pump gaskets & kit.
Gene721
Kubota L2350F FEL LA452S
Oct 4, 2024
14
Cornelius
I have a Kubota l2350 tractor that has been idle for a long time. Now my mechanic is doing a full service and replacing everything that can be replaced with new parts. At the moment, the tractor has 900 hours and works well. The plans include replacing the clutch, injectors, cleaning and servicing the fuel pump, replacing the seals and gaskets. Please do not advise where to send me the fuel pump for repair, my mechanic is a real diamond and will do everything in the best possible way. At the moment, I can not find a manifold gasket, Denso fuel pump gaskets and a Denso Fuel Injection Pump Rebuild kit . My engine is D1102. Please tell me where I can buy all this.
Flintknapper
L2350DT
May 3, 2022
1,872
2,358
Deep East Texas
Intake manifold gasket shouldn't be a problem.
L2350 does not use a 'fuel pump/lift pump' it is gravity fed, so you can mark that off the list.
Kubota dealer should be able to help with an injector pump rebuild 'kit'. Otherwise the individual components are still available.
Gene721
Oct 4, 2024
14
Cornelius
Thank you very much, this is exactly what I need to be happy. My mechanic showed me 2 more gaskets from the injection fuel pump that he needed, one made of tin, square, the second one made of cardboard completely fell apart.One looked something like this. Unfortunately I don't have any samples, as the mechanic put everything back together so that the tractor would be in working order.
8,251
Thank you very much, this is exactly what I need to be happy. My mechanic showed me 2 more gaskets from the injection fuel pump that he needed, one made of tin, square, the second one made of cardboard completely fell apart.One looked something like this. Unfortunately I don't have any samples, as the mechanic put everything back together so that the tractor would be in working order. View attachment 139135
You don't Willy Neilly replace that / those shims, they are sized exactly to set the timing on the injection pump.
And if they are on there, then there would be no logical reason to change them.
As far as you not having a local dealer, do what I do and order from Coleman Equipment.
Flintknapper
L2350DT
May 3, 2022
1,872
2,358
Deep East Texas
Correct (as usual).
For that engine there are three shims available (in different thicknesses)
0.15mm
0.30mm
0.45mm
The injection pump cover gasket should be 15296-51660.
OP would do best to contact Coleman/Messicks/Other for parts. They should have a complete breakdown.
