Flywheel bolts
Skipmyers
New Holland
May 28, 2024
Somonauk IL
I bought a Kubota V1702 and it came with no flywheel bolts. Can anyone tell me what size they maybe or a part number?
Thanks to all, Skip
10,979
It's not a simple answer, as there are mutiple options for the bolts, it depends on the flywheel your using.
FYI: There are not normal bolts, here are a few examples of various Kubota Flywheel Bolts.
DO not use a NON flywheel bolt.
Skipmyers
New Holland
May 28, 2024
Somonauk IL
Hey all! Sorry to be so Vaage on engine ID. I do not know much about it other than its was out of an old reefer unit as it says Carrier on the oil pan? I could not find and tag on the block itself, just on the intake says 1702.
I'm replace a V1902 that has a rod knock in a New Holland 555 skid loader. Its a bit less horsepower but only using it to move things around the yard. I was looking for a V2203 but people want stupid money for them used! I am just looking to reattach the bell housing and flywheel to test run before i install in the machine. Once the old engine is removed, I'm pretty sure I can use the old flywheel bolts off the V1902.
I saw some of the bolt prices, that's insane!
Thanks all, just looking for bolt diameter and thread pitch. Have a good Thanksgiving!
