Flow reducer
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Ok I went to my local toy store and seen this
http://www.landpride.com/products/592/sgc05-series-claw-grapples
After my drool started to slow down I got to thinking (Yes I hurt myself). If the Lovely Wifey-Poo lets me get it I could use the diverter to power a my shoot deflector with a small ram on my snowblower. Is there a way to reduce the amount of flow? I understand that a small ram will not handle the amount of fluid being diverted.
MtnViewRanch
877
320
Lakeside Ca.
Yes you can get a flow restrictor. You should be able to get one from Land Pride. If not , I have them. ;)
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Come to think of it now, I think Wildfire put an eletric actuator on his chute to change direction if I remember correctly. Maybe he'll be along shortly.
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
I had a Kubota electric actuator on it and after one season it was fried. Water got in to the motor and caused it to go bottoms up :mad:
Wildfire
There are pressure restricters you can put inline to reduce the amount of flow on a hydraulic system. I've used them many times for different applications. They have an adjustable knob on them and work really well.
As for the deflector on a snow blower chute I've used a 12 volt linear actuator many times as well for customers and they've worked flawlessly. I've never had one return. Just fab up a few mounting brackets, run the wires to a two way switch and your off to the races.
Our 5740 has the rear blower but all control are hydraulic.
http://www.northerntool.com/shop/tools/product_200336352_200336352
http://www.princessauto.com/pal/en/Actuators/12V-DC-8-in-Stroke-110-lb-Linear-Actuator/8272536.p
