Finally, a Replacement Battery
4,067
Well…. I’ve had my M4700DT now since May ‘18. I bought it with 400 hrs on it from its second owner….(who’d deceived me about a failed alternator by removing the idiot-light and having installed a brand new battery…. so I was the idiot…..but I’ve told that elsewhere.)
The battery was dated 5/18…an EverStart H7 from WalMart. The H7 is the largest capacity for many vehicles… most CCA and 5 yr warranty…. so it lasted 7 years.
When I took it in yesterday, I also had 2 other old batteries out of my boat I’d replaced with EverStarts last summer….and had paid $12 re-cycling fee for each since I didn’t have them with me during the purchase)….. so I was attempting to return them for “credit” as-well. WM has changed their policy…. Nope. Don’t want ‘em. Won’t give credit. Unless I had the recp’t WITH me…they wouldn’t take them, even for disposal. :mad:
(I took them to AutoZone who issued $10 ea store-credit.)
But WM is the best battery-deals around my parts and the EverStarts have always been good for me.
HOWEVER, their H7 is now $180 plus tax, etc. :oops:
They have an ”H6” (a new designation for me)…. a 1-yr warranty battery with 615 CCA for $70.
(Another ”H6” battery next to it, looked idntical, with a different label 2-year warranty was $100) :rolleyes:
I picked them up individually and they felt to be the same weight…so I decided they’re actually the exact same batt.)
Since the tractor (an open station) actually has very little electrics on it… I figured ”Good ‘nuff ! and so that $70 is what I installed. (the only ”extra” electrics are a couple LED-lightbars I added for night work….so the batt doesn’t have to deal with anything except starting.)
Get ready for higher-prices on batteries, Guys…. they’re made down in Old Mexico and have to be Imported.…and you-know-who has added a fee to anything imported.
WI_Hedgehog
Apr 24, 2024
1,126
1,639
Milwaukee, Wisconsin, U.S.A.
Quick note: My experience is W-Mart sells "remanufactured" batteries, namely batteries that went to China for "recycling" and, through the cheapest means possible, get re-stuffed. Longevity has been D.O.A. to "poor" to "reasonable." Sometimes they run for a while then drop a plate and are non-functional (suddenly dead, which in my personal experience sucks, and is how I found out about the situation years back). Now, maybe it's good value for the money and purpose, that's up to you. Note some of the LiFeO4 batteries from China are similar, and a few lit themselves up--there's no free lunch.
Blue2Orange
Apr 3, 2025
398
277
Bayview Township
On my previous tractor a NH compact switched out the lead acid for the Optima Yellow top deep cycle AGM. Don't remember exact number of years of use before it needed replacement with another identical battery except made in Mexico vs. the old USA made. Maybe 12-14 years. No battery tender until the last year or two. Tractor was down to minimal use at 50-70hrs/year. 2nd didn't last nearly as long. Still able to start, but load testing had me concerned. Replace it just last year. Then of course I trade it in for a Kubota.
Vehicles replacement batteries have been Interstate branded model over the past quarter century. No disappointments yet. If available probably will go with Interstate on the KuBx when needing replacement.
Might still invest in a Red Top Optima when the OEM battery dies. Do have the Kubota battery on an inexpensive Norco charger/tender. Tractor time is usually Autumn to Spring. Don't remember firing up KuBx this month yet.
Bee-Positive
Nov 16, 2022
878
857
Amsterdam, NY
Since 1992 Texas State law requires retailers to accept used motor-vehicle batteries or other lead-acid batteries for recycling. (Any battery which contains lead and sulfuric acid).
jaxs
B1750HST
Jun 22, 2023
1,032
792
I've been using W-Mat batteries for decades and never had one fail until long after warranty expired. When I worked at an auto repair the battery manufacture furnished free loaners so that customer's battery could be slow charged after an alternator failure. I've followed that believe ever since and believe that's why i get long service from batteries. I have 3 Deltran Battery Tenders on something all the time.
I buy the largest battery that will sit in holder (often group 65) not necessarily most expensive or longest warranty.
6,255
What's interesting about the 'OPTIMA' red tops is that you're NOT supposed to use the side posts for high current drains ! I questioned them about it, got some doubletalk nonsense but it seems that the connection between the top posts and side posts will MELT. The ONLY reason I have it was FOR the side post 'feature'. When(if ) it fails, I'll just toss in a normal side post battery. The redtop was free 10-12 years ago.
It'd be nice to access the cells of 'regular' batteries to add acid once in awhile. Between heat and recharging, acid 'magically' goes missing....
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
281
82
Southern IL
I have had really good luck with Rural King batteries. Replaced one in my Suburban with same a few years ago. The old one lasted 10 years.
4,067
Thx for that. I”ll ck on it…and see if the WM Mgr in Marble Falls (a guy named “Dale” can be embarrassed. Perhaps the State Law only applies to “core charges” when buying a new batt..?)
4,067
I”ve never witnessed a “remanufactured“ WM battery, so I don’t know about those. I”ve only purchased new mfr batts.
If you can believe AI… None of WM’s new batteries come from China.
Clarios (split from Johnson Ctrls) still makes WM batts in Mexico, but other mfr’s also make WM batts in Germany, So.Korea, and India.
The H6 I just bought has a ”made in mexico” label.
jaxs
B1750HST
Jun 22, 2023
1,032
792
Remarks about Wal-Mart's remanufactured batteries likely originate out of hatred for Wal-Mart .
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
652
770
NE FL
I too purchase Walmart batteries. I won't ever buy their "Value" brand again although I probably got what I paid for on them. I bought two of the group 26 value batteries once. They both failed just before the 1 year warranty ended. Walmart replaced them with the same and that pair also failed in less than a year.
I actually replaced them with Walmart lawn tractor batteries. You would be surprised what you can get away with on those. I just replaced them again because one failed at almost 3 years old. I have had several of their lawn tractor batteries last up to 5 years on my gate opener.
I have found if I keep seldom used batteries on a solar maintainer they last much longer. Lately I have used 10 watt panels without a controller and add a blocking diode to prevent any discharge through the panel.
WI_Hedgehog
Apr 24, 2024
1,126
1,639
It came from watching the supply chain. I run a lot of batteries due to hobbies and batteries get expensive. I'm simply after the best bang for the buck.
Admittedly, things change, like the implementation of tariffs, so I could be out of date. If W.Mart had excellent quality for the price with great reliability I'd shop there, but that doesn't seem to be most people's experience.
4,067
I had a buddy buy a light airplane (Cessna) and operated it for a year before his first annual inspector showed him he’d been duped by the previous owner….who had installed a WalMart lawn-tractor battery in it. When I posted that info at an aviation forum… two other airplane owners admitted their airplanes had also operated just fine with them. :cool:
(Price diffeerence: WM Lawn tractor =$30. Airplane lead-acid = $200)
(Marine, ag-equip’t, and airplanes…. maybe some others also…. batteries are built to withstand rough-useage, pounding, vibration, deep-cycling, non-spillable, etc. Maybe lawn-tractor batts are also…??)
4,067
I have a friend who has had “horrible” experiences with WM batts…which he calls “NeverStarts”….
My experience is the exact opposite…. EverStarts have been less expensive and outlasted every other brand I’ve ever owned….. (and I have Fourteen…count ‘em…14… lead-acid batteries in my equip’t.… ALL of ‘em, now EverStarts.). They typically last about 25% longer than their warranties.
My trucks and cars have the WM 5 yr batts…which usually die around 7 yrs.
I believe the difference is that my friend is a retired aircraft mechanic (former TWA) …and, just like my electrician and plumbing and auto-mechanic buddies… who all have the Worst open-wiring in their homes….the worst patch-work plumbing… and the junkiest cars….. he has the WORST-maintained stuff including 3 light-airplanes that haven’t flown in decades. (Yes… DECADES. They’re sitting outside on the east-side of Toledo-Bend slowly returning to Bauxite.). 😢
Maybe that’s a clue as to why his batteries don’t last.
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
107
89
duluth mn
I havevused WM batteries in my boats, RV, ZTmower, and have one on amantainer and all of them are 2 to 5 years old.
I have never nad one last less than 5 years!
Don
PS. Iam not a fan of WM, but I can not beat there batteries!
WI_Hedgehog
Apr 24, 2024
1,126
1,639
Thanks for adding your experiences, it could certainly be I've had a run of bad luck and I need to give them another try.
7,544
All I buy is Walmart batteries. Never had a problem with them, and always last way past warranty. Local mechanic shop quit handling Interstate a couple of years ago because of too many returns.
7,305
My only experience with WalMart batteries has been limited to the small lawn/garden type many years ago.
Wasn't good, so I've steered away from them since.
I've trusted NAPA batteries, although NAPA doesn't make batteries either.
For all I know, the WM and NAPA batteries come from the same manufacturer.... 😲
One thing for sure.....the prices of batteries have escalated greatly in recent years.
