FEL Valve Rebuild Kit
schmellba99
L3800
Jun 4, 2012
95
I have a Husco valve, Kubota Part no. 75540-61013 (has been superceded by 75540-61014). Does Kubota make a rebuild kit for this hydraulic valve? I have some binding in what will be my bucket curl/dump side and while I have it on the bench, would like to replace any guts that are in need.
I will call my local dealer tomorrow, but wondered if there is an aftermarket kit you guys know about that will do the job that I could source as I expect the kit from Kubota to be about 10x what it should be in cost.
8,228
There are more than likely only going to be available from kubota.
Depending on what parts you really need the kits are not that expensive, $18.40 and 18.53 for the 2 seal kits.
The detent kits are quite a bit more.
I would find out what you need then see what it's going to cost.
schmellba99
L3800
Jun 4, 2012
95
I need the small spring in the detent kit, that's it. Hate to pay $150 for a kit when all I need is a $1.00 spring. Ordered one off of Amazon that is pretty close to the measurements I took, we'll see if it works or not.
6,306
I'd go to your local hardware store and check out their spring supply. Buy 3 or 4 if you can't be pretty sure what will work. They'll cost a dollar or so each. Cut one to the length you need. It just hold the detent balls in place.
