FEL Plate Compactor - Anyone have this?
MOlivin
L6060
May 15, 2023
47
MO
I'm trying to find a plate compactor and came across a couple of companies that have these types of units for skid steers/tractors. Has anyone on here used on for your tractor?
The specs show a Hydro flow between 12-21gpm. I've for an L6060 with the specs of:
Total Flow 14.1gpm
Pump output 9.4gpm
Power Steering 4.7gpm
I'm assuming the Pump Output would have to be at least 12gpm to run this thing, correct? Not the "Total Flow"?
Thanks all!
8,717
Yes you're right, you don't have enough flow to run it.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
782
678
E.
I've used something very similar.
Your L6060 is perfectly capable of handling it if you just plumb the required hydraulics through an after-market PTO driven hydraulic pack vs the L6060 pump and Bob's your uncle.
There is hundreds of manufactures of them out there and lots of people simply make their own and run all kinda things like log splitters, lumber mills, wood processors, jack hammers, etc...
These rear power packs are very useful for a lot of things and new for the size your talking about are pretty cheap at less than $3k probably closer to $2K new or build yourself for even less.
MOlivin
L6060
May 15, 2023
47
MO
That is highly promising. Never seen the power packs before. Thanks for the info!
